Just tried to start the 36 after not using it for 4 days.
All dash lights come on and don't dim when turning the key (apart from the oil level light, which does dim)
Connected a volt meter to the terminals in the engine bay (battery in boot) and voltage showing 11v with no drop when the key is turned. (obc showing 13.5 v when running last weekend)
Immobiliser LED in the dash turns to green when unarmed and red when armed.
When the key is turned, nothing happens, not even a click.
Is it time to remove the toad alarm? I'll try a jump start over the weekend...
Low battery or immobiliser?
- Homo Hair
Low battery.
Should be 14v+ (iirc) when running.
Could be the alternator isn't charging properly.
schnaarf
Rats. Thanks Jhonno, I'll get it running and check the alternator output
schnaarf
No luck. Got the jump leads out but still nothing. Obc showing 13+ volts but not even a click.
Got to be the toad alarm hasn't it.
schnaarf
Would a buggered earth strap cause this problem? Took it off and put it back on between it starting and not, which is a bit of a coincidence. I'm not with the car at the moment so just pulling ideas together for when i get back later.
- Homo Hair
Yes it could I think.
schnaarf
Earth strap
Problem solved
Problem solved
