M30 ecu change
johnl320
Post Fri Feb 17, 2012 5:57 pm
just swapped from the original 150 ecu that came with the e32 engine, to a 179 from an e34. What difference, better starting hot and cold, smoother power delivery and no more cutting out when slowing down for junctions,.
Not sure if the 150 had a fault or I've cured a bad connection while removing and replacing it.
Any else running a 150? [/b][/i]
Post Fri Feb 17, 2012 6:07 pm
Think I am,
Did you open the 150 up??
Post Fri Feb 17, 2012 6:14 pm
The 150 is Motronic 1.1, with two PCBs, so more likely to go wrong than the later 179 Motronic 1.3 single board unit.
Motronic 1.3 has better resolution (more memory map locations).
I also did this swap when I had an E34 535iSE.
You could make it go even better with a chip upgrade. winkeye
johnl320
Post Fri Feb 17, 2012 6:24 pm
Rav335uk wrote:Think I am,
No mate, still sat in the footwell
Post Fri Feb 17, 2012 6:26 pm
Maurice has answered what I was going to say John about the 150.
johnl320
Post Fri Feb 17, 2012 6:28 pm
Speedtouch wrote:The 150 is Motronic 1.1, with two PCBs, so more likely to go wrong than the later 179 Motronic 1.3 single board unit.
Not just yet mate, saving pennies for timing chain for the IS
Post Fri Feb 17, 2012 6:29 pm
No worries, fella. :)
