I can't remember if it fits or not but would a small case E30 LSD fit an E21?
Pretty sure the casing won't bolt up but possibly the LSD unit will work on the E21 cwp?
E21 diff compatibilty
Dave_M3
I know the casing definitely won't bolt up, and the E21 diff is a lot slimmer than E30 ?
sweep
A e21 diff looks like something from a triumph herald.
- E30 Zone Meets/Events Team
In short Dave,
NO!
You can modify the E30 rear beam to fit onto the E21 though.
iirc, it's about 5mm difference between the 2 subframes.
Jasons done it on his track E21.
NO!
e21Jason
You can swap the e30/36 internals into an e21 diff case, but you have to grind the inside of the e21 case to make it fit. After that it is either modding an e21 beam to take an e12 diff. Or choping about an e30 rear axle to fit.
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
Dave_M3
Cool, cheers lads. That was pretty much what I was thinking would be needed. Just wanted to be sure
