m40 to m42 auto to manual conversion help needed
chappers7
looking for a suitible doner engine for a m42 conversion, can i use an auto engine then put my flywheel and gearbox on it or will i have issues with ecu's etc cheers
ECU won't give any problems, although the gearbox input shaft will, unless you fit a correctly sized spigot bearing into the end of the crankshaft.
rix313
You have an M40 auto and want to convert it to M42 manual?
If an engine comes from an auto car, the auto has to do with the gearbox, not the engine so it doesn't matter.
If your car is an auto you will need to fit a manual pedal box to allow for the clutch pedal and smaller brake pedal. You will then have to fit the appropriate clutch master and slave cylinders and pipe work.
No, he has an M40 manual and wants to fit an engine from a M42 auto. At least that's how I read it.rix313 wrote:![]()
chappers7
thaqts right, having diffeiculty sourcing a manual engine thats why i asked
So what's this M42 engine coming from? No UK M42 engined E30 ever left the factory with an auto box attached to it.
