Honda S2000 powerd bmw e30 track car
s2000powerd30
Post Fri Feb 10, 2012 3:06 pm
So i bought this e30 of my mechanic he previously had an s2000 engine in it, so saves me alot of hassle as all the fabrication work has been done....
Hers how i picked it up, in a sorry state i know but it wont be for long
Here you can see the fabrication work so the engine sits right back an as low as possible for improved handling...
s2000powerd30
Post Fri Feb 10, 2012 3:14 pm
So i owned this s2000 an decided to to use it as the doner car, there is only 87000 mile on it an has been well enough looked after, i got it for a good enough deal an i have sinced sold the rest of the car...
I will be using the engine, gearbox, prop shaft, digital clocks, an the wiring loom
So we got the car on the lift an the lads started cutting the rear arches out so we can fit wider wheels
Nobby_N
Post Fri Feb 10, 2012 3:15 pm
Nice
s2000powerd30
Post Fri Feb 10, 2012 3:24 pm
Few pics from underneath the car...
s2000powerd30
Post Fri Feb 10, 2012 3:27 pm
4 or 5 stud wheel conversion for the rear
Underneath strengthened for pedal box to bolt to
s2000powerd30
Post Fri Feb 10, 2012 3:31 pm
Heres the fabrication work from the inside
Mount made for the pedal box
s2000powerd30
Post Fri Feb 10, 2012 3:36 pm
Engine out of the s2000
s2000powerd30
Post Fri Feb 10, 2012 3:39 pm
Engine set into the car
Radiator brackets made an set in
s2000powerd30
Post Fri Feb 10, 2012 3:42 pm
Exhaust bracket made to fit the exhaust on
Definitely rough and ready.. Could be fun! :)
Post Fri Feb 10, 2012 3:44 pm
s2000powerd30 wrote:Image
I would be sorting this out asap!! Ouch! 8O 8O 8O
s2000powerd30
Post Fri Feb 10, 2012 3:46 pm
s2000powerd30
Post Fri Feb 10, 2012 3:53 pm
Aluminium fuel tank
These seats only weight 4kgs each
s2000powerd30
Post Fri Feb 10, 2012 3:56 pm
So i left the prop shaft away to get lengthend
s2000powerd30
Post Fri Feb 10, 2012 4:06 pm
Wiring loom an dash clocks with power going to them
s2000powerd30
Post Fri Feb 10, 2012 4:13 pm
Pedal box sitting on its mount
Also have the fibreglass moulds
s2000powerd30
Post Fri Feb 10, 2012 4:15 pm
New bonnet pins
Wheels sanded ready for painting
How the car is sitting now im hoping it is running now very soon
s2000powerd30
Post Fri Feb 10, 2012 4:17 pm
s2000powerd30
Post Fri Feb 10, 2012 4:21 pm
Jhonno wrote:Definitely rough and ready.. Could be fun! :)
Wont be rough by the time its finished mate, yes definatly will be ready, car could be going to tts for a rotrex supercharger conversion which would see 450 bhp an 280 torque....
These engines rev to 9000 rpm standard an are 240 bhp
Kieran_n22
Post Fri Feb 10, 2012 4:23 pm
wow, quite a crazy idea. Sounds to be very good! Keep it up. These engines can wiithstand big power!
s2000powerd30
Sorry forgot to add the spec its been built for accleration..
J,s racing crown wheel and pinion
Kazz 1.5 race diff
electric power steering from corsa
evo 7 brembo 4 pot brakes
m3 widearch kit
omp rollcage
5 sets of alloy wheels
2 motordrive bucket seats
2 3 inch harnes,s
stilo intercom system
newly polybushed
spare s2000 head
spare s2000 gearbox
spare wheel holder removed
alloy fuel tank
braided fuel hoses
braided brake hoses
new steering wheel
weight is under 900 kgs
coilovers (cant remember the make)
Post Fri Feb 10, 2012 4:31 pm
Considering the spec and attention to weight, you'd do well to sack of the shite and heavy Alpina reps for something light and strong!
s2000powerd30
Post Fri Feb 10, 2012 4:38 pm
Jhonno wrote:Considering the spec and attention to weight, you'd do well to sack of the shite and heavy Alpina reps for something light and strong!
Yes i would buy something lighter, i have to keep the wheels 17 inch as to fit over the brembo brakes
Im also going to paint the roll cage an the wheels this colour
The car is getting painted ford frozen white
s2000powerd30
Post Fri Feb 10, 2012 4:42 pm
Kieran_n22 wrote:wow, quite a crazy idea. Sounds to be very good! Keep it up. These engines can wiithstand big power!
There is a 700 bhp s2000 running standard internals on s2k uk....Rotrex uk are happy for these to run at 450 bhp without an issues.....
I have a tommy makinen evo an its 382 bhp if i where to go any more id need to change the rods at the very least
Post Fri Feb 10, 2012 4:44 pm
White on green works ok..
Team Dynamic wheels? Pretty cheap.. Compomotives turn up 2nd hand a fair bit also.
s2000powerd30
Post Fri Feb 10, 2012 4:51 pm
Would they be 5 or 6 spoke wheels? Cant picture them in my head an how much would a set of 2nd hand 17s cost me?
Here is pic of my 6 spoke compomotives on my evo
