M20B25 Main Bearing Oil Clearance
b12rlw
Post Thu Feb 09, 2012 7:49 pm
Hey folks, Ive just bought a set of mains for an aplication as follows..
Crank Journals - 59.97mm
Main Brg OD (ie. block id) - 65.04mm
Brg Thickness - 2.498mm
my calcs for a lubrication clearance are as follows..
gap between block and crank -> 65.04 - 59.97 =5.07
Brg thickness (accounting for both shells) -> 2*2.498 = 4.996
Subtraction of the two resulting in oil film clearance ->
5.07-4.996 = .074mm
my question is.... Is this a large enough clearance??
Post Thu Feb 09, 2012 8:32 pm
Look for the M3 rebuild by x-works. I believe he goes into this in some detail in his build of the engine.
