Help please. Annoying squeal from rear
Hayden0
Post Sat Feb 04, 2012 1:18 pm
I'm getting a quite loud squeal from the rear of my car when I go over 20mph to approx 50mph. The noise is a lot louder from the passenger side than the drivers with the windows down. When I apply the foot brake or handbrake the noise still persists. The back plates are clear from the disks. Any help on the matter would much be appreciated
Hayden0
Post Mon Feb 06, 2012 12:53 pm
anyone?
e301988325i
Post Mon Feb 06, 2012 12:59 pm
please advise, year, model, engine & disc's or drums at the rear?
I said:
e30topless said:
lock the wife in there
**BANNED**
Post Mon Feb 06, 2012 1:17 pm
Take the wife/GF/mother in law out of the boot! :D
Youth is wasted on the young.
Hayden0
Post Tue Feb 07, 2012 12:22 am
It's a 89 325i SE saloon with rear disk and handbrake in the drum of disk. Diff seems to sound like a aero plane going down road when I have window down, could it be the diff dying on me? Cars done 121k
Post Tue Feb 07, 2012 12:27 am
either the diff or rear wheel bearings,
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Feb 07, 2012 6:46 am
A very quick test is to take the handbrake gaitor off, mark the position of the nuts underneath and then slacken them off. THIS IS NOT how you adjust the handbrake cables, but as a quick way of loosening them it works.
If the noise goes away, then your handbrake shoes were dragging on the inside of your brake disc. Return the nuts to their proper position, and remove the brake discs to assess the condition of the brake shoes.
If slackening the nuts didn't make the noise go away, then jack up the rear end and give each wheel a hefty tug left to right, then up and down. If the wheel wobbles noticeably, your bearing is probably dead.
If the wheels don't wobble, it will be time to assess the diff.
Hayden0
Post Wed Feb 08, 2012 7:53 pm
its not the handbrake shoes rubbing ive checked that out, ill have to jack up and check the wheel bearing but im sure there is no play because its just been mot'ed the other month. thanks for the help guys
