E92 Topmounts On E30 318is
bassjamm
Wed Feb 01, 2012 11:38 pm
Hello...
I've heard that the E92 top mounts may fit the E30 318is and offer a 15mm-ish drop.
Can anyone confirm this?
Jamie
Ajsingh
Thu Feb 02, 2012 11:18 am
The top mounts dont, its the hat of the spring that fits and gives the drop.
E30 Crazy!
einarsss
Thu Feb 02, 2012 4:02 pm
its more like 10-12mm drop, but a cheap way to get some extra drop :)
Kedge
Thu Feb 02, 2012 4:28 pm
I think these were what i was on about the other day when i posted up a new thread.
So the E92 spring top hats will fit E30 springs, spring rubber and top mount?
Part #8 in this pic (BMW part #31336764093);
Instagram - Kedge85
Cook318IS
Thu Feb 02, 2012 4:42 pm
Kedge wrote: So the E92 spring top hats will fit E30 springs, spring rubber and top mount?
Im using these, they fit the e30 springs, rubber pad and top mounts fine. The only difference is literally the depth of the top hat.
Kedge
Thu Feb 02, 2012 4:48 pm
Wicked. I'll be on to Cotswolds now then.
They fitted in your sig? I'll be running 16" Hartges as well, on 35mm Eibach Springs. Using 3mm spring pads all round as well. Hopefully be ok on a chromie.
Instagram - Kedge85
Cook318IS
Thu Feb 02, 2012 4:59 pm
Yeah they are fitted in my sig. Im rocking h&r 30mm springs with 3mm rubber pads up front and thicker 10mm pads on the rear.
Not very good pics but:
Kedge
Thu Feb 02, 2012 5:02 pm
That looks spot on. Waiting on a price now :)
I'll stick with the 3mm rears for now since the chromie has a higher arch profile on the rear, see what it's like once it's back on the deck and settled down.
Instagram - Kedge85
Cook318IS
Thu Feb 02, 2012 5:04 pm
Kedge wrote: I'll stick with the 3mm rears for now since the chromie has a higher arch profile on the rear, see what it's like once it's back on the deck and settled down.
Thats a very good point, i went for the thicker rear pads to give it a bit more rake but it would probably look stupid on a prefacelift with its arch line
kitch
Thu Feb 02, 2012 5:19 pm
Cook318IS wrote:
Your car reminds me of Lightning McQueen here haha.
rix313
Thu Feb 02, 2012 5:34 pm
Cook318IS wrote: Not very good pics but:
Yeah you're right, they look shit :roll: :roll:
winkeye winkeye
BATTS91
Thu Feb 02, 2012 6:27 pm
hey any price from bmw on these yet kedge? im interested in getting some heard there like $12 in us cant find a website with som over here ? top man
sweep
Thu Feb 02, 2012 6:29 pm
I had a pair delivered today it think they were £16 odd.
BATTS91
Thu Feb 02, 2012 6:35 pm
really that cheap is that from cotswold on here or your local bmw mate might have to give a call tomorrow then :) also is the part number above correct ?
sweep
Thu Feb 02, 2012 6:46 pm
Sytner sheffield
bassjamm
Thu Feb 02, 2012 7:45 pm
Hey guys...thanks for all the input here.
Anyone got a part number for the bit needed? Will they sit on any set of springs fitted to an E30 that were a straight swap from originals? Mine lowered 40mm on springs, they were just a direct swap, no retro fitting from what I can gather.
If I add these, it should drop it to 50mm-ish right?
Kedge
Thu Feb 02, 2012 7:51 pm
Still waiting on a response from Cotswolds.
The part number is in my earlier post with the picture, from the info I have you're right in the amount they'll lower your car. Should be suitable for any spring that fits an e30.
Instagram - Kedge85
Dezzy
CR24v it's a lifestyle
Thu Feb 02, 2012 8:07 pm
sweep wrote:I had a pair delivered today it think they were £16 odd.
Was that the part number we talked about Pete?
sweep
Thu Feb 02, 2012 9:01 pm
Yes mate but the ones i have just got are the second set ive had now.
bassjamm
Thu Feb 02, 2012 11:00 pm
Ah Kedge...right you are sir. Missed that.
So are these for front and back? And are they fairly easy to whack on d'you think?
BATTS91
Fri Feb 03, 2012 2:17 am
rear doesnt have top hats ;) take a peek fella there independant so basically springs arnt on the shock
Kedge
Fri Feb 03, 2012 7:20 am
You can still drop the rear a few mm though using the thinner spring pads.
Will ring Cotswold later if i don't get a response this morning, usually pretty good though.
Got my new front spring pads through yesterday as well :cool:
Instagram - Kedge85
bassjamm
Fri Feb 03, 2012 9:03 am
Ah right. As you've probably noticed I'm a bit of a dunce when it comes to all this, ha!
So I can go for these E92 top hats on the front, use thinner spring pads on the back and I should be riding a little lower.
This should be a nice simple fix until I can afford some GAZ coilies.
sweep
Fri Feb 03, 2012 9:04 am
yes thats correct......you dont really need coilovers on a e30?
bassjamm
Fri Feb 03, 2012 9:23 am
Depends how low I want to go :p
I'm probably going to upgrade the whole set up in the future, either by way of some decent coilovers, like GAZ ones, or by way of the Blistein b4/b6 and some decent springs, with the mods mentioned above.
We shall seeeeee!
Kedge
Fri Feb 03, 2012 9:34 am
I don't think you need coilovers either. You're paying a lot of money for features few people ever use.
With the tophats and 3mm spring pads on the front you're dropping it at least another 15mm. Plus another 6 on the back with the 3mm spring pads there.
Just got a price from Cotswolds, £16.74 for the pair of top hats. Think the springs pads were about £3.00 each.
Instagram - Kedge85
Kedge
Wed Feb 08, 2012 5:28 pm
Got my new top hats today and painted them up, took a pair of struts apart today as well to give an idea of the difference between the E90 and E30 tophats.
Hard to tell the actual height difference but it is clear to see the top mount will sit quite a bit lower.
Here's the difference in springs pads to.
I reckon you're looking at something around a 15mm drop on the front using these for little more than £20 :cool:
Still no idea how to tell before taking the struts off what upper spring pad you have. The ones i took apart today were off a chromie 325i and i have some at home off a facelift 325iSE which looked more like 3mm pads :mad:
Instagram - Kedge85
Wed Feb 08, 2012 7:17 pm
Kedge wrote:Hard to tell the actual height difference but it is clear to see the top mount will sit quite a bit lower.
The top mount will remain in the same place but the top of the spring will sit higher up in the wheel arch hence the car being lower.
Wed Feb 08, 2012 7:39 pm
Nice mod this - just can't be arsed to take my struts out again though :o:
Maybe in the summer :D
Kedge
Wed Feb 08, 2012 8:59 pm
Yea that's more like it, my explanation was a bit on the shit side :o:
Instagram - Kedge85
clipper
Wed Feb 08, 2012 9:39 pm
Watching this with great interest.
Do I understand that you'll end up with about -15mm at the front but only -3mm at the rear?
Won't it look a bit 1980's Streetmachine ?
Kedge
Wed Feb 08, 2012 9:46 pm
H&R Cupkit is 60/40, and i like the nose down stance.
I'm not ruling out wanting to lower the rear more but the only option there is different springs. Will see what it's like once the car is on the road which is some way off.
Instagram - Kedge85
G-Bear
Mon Feb 27, 2012 10:54 pm
This is a great little thread. Getting together everything for a full suspension upgrade for my IS. Just researching into what to get. I just put a fresh set Eibach Sport Pro springs as a start and to get it through the MOT. It was lowered before and the new springs have dropped it almost the same, however the rear could be dropped a touch more to satisfy my taste. Those 3mm spring pads would be ideal.
Only one concern, looking at that picture the are considerably thinner than the 10mm (obviously), will these wear/perish quicker??
