A while back, I had an air leak, and while at a Dyno session the operator tuned up my AFM to force the car to over fuel to compensate (as a temporary measure). I never got around to fixing this, and it has recently come to my attention that I should get it sorted!
Any advice? Not really sure what I'm doing with it. Is it something I should get a professional to do?
Overfueling - advice on adjusting AFM
cee
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
johnl320
If you do the inlet manifold heater mod that I have just done you will probably find and get rid of the air leak, then its a case of getting the AFM back to its origonal setting
Here is my thread and there is a good write up on m42club.com
http://www.e30zone.net/modules.php?name ... c&start=25
cee
Sorry, forgot to mention that the air leak has since been fixed (I think) I replaced all the breathers as they were all perished and cracked.
kam-325i
if you have fixed the air leak, then you need to reset the AFM, youll need a CO meter to do this....
cee
What, one of these?kam-325i wrote:if you have fixed the air leak, then you need to reset the AFM, youll need a CO meter to do this....
Once I've got hold of one, what figures should I be getting?
johnl320
On tickover, with car locked in a garage, bird should die between 1-2minutes. Less than 1= too rich, more than 2=too lean
cee
Hahaha brilliantjohnl320 wrote:On tickover, with car locked in a garage, bird should die between 1-2minutes. Less than 1= too rich, more than 2=too lean
