Evening everyone,
Once again looking for help regarding my new alloys. They are 15'' split rims, 7J, offset 26..
I believe my car has been lowered 60mm, not entirely sure but on 17'' rims on the rear on low profile tyres the alloy rim just goes past the arch and is almost level (could be a clue?)
So, which size tryes am I best running in order to keep the archers neatly filled and not to empty, and most of all not too shallow the car is stupidly lower? I am useless with tyres! My opinion is low profiles will sit the car too low and general size will not fit in the rear arches properly?
The car is currently on 17'' rims with low profiles (I will add the trye size when home), but roughly from what we know ie the new 15'' and the 60mm drop would you suggest?
Please note I may have a play with my ten and five mil spacers.
Hope this is clear enough.
best tyres for my dimensions?
svenga
I would say you are either into 205/50/15 or the standard size for 15" BBS is 205/55/15.
Personally I would be looking at going for 205/55/15 unless you are wanting to have the wheels almost poking out beyond the arches.
What sort of look are you going for?
svenga
Lee, tyres poking from arches are not really something I'm over interested in (even then I can play with hub-centrics). I just like the tyre wall low and the car low, but not low where I am asking to rip the underside off on speed bumps. Swings and roundabouts eh!
I wonder if there is a calculator somewhere, or if anyone has an 15'' rims lowered 60mm to show an image and and worrys..
