Auto TPS problem (Internal Pics of TPS)
PG325
Post Sun Jan 29, 2012 2:19 pm
I drilled my TPS cover last year, today I cleaned it out again with a spray, after doing this I could hear something rattling inside, I pull the lid off to reveal I had drilled to deep and damaged the circuit board :o:
I think the part that has broken is to do with the auto box and not the control for fueling, if you look at the pics you can see the broken part, it appears to run on a sliding potentiometer.
The top part of the switch appears to control the fueling and can clearly been seen in the attached video :D clicking when off idle, then the second phase contact switch at about 75% movement.
My car is actually a manual but I replaced the loom with that from an auto a couple of years ago, I've must have been driving around without it causing any problems.
My questions are:
1. Can I still use this TPS?
2. Can I swap to a manual TPS and splice in the plug from my old manual loom?
Post Sun Jan 29, 2012 6:54 pm
Never seen the inside of one of those before!
If the two switches at the top are working, then it's OK to use on a manual car. The carbon track and its wiper are only used to supply info. to the gearbox ECU of a switchable auto.
PG325
Post Sun Jan 29, 2012 7:29 pm
Well I've tested the continuity off idle at at WOT, all seems OK, it's going back on the car, I might at some point splice the manual version but it's too cold at the mo!
Post Mon Jan 30, 2012 5:07 pm
Paul. PM mate :D
