I'm trying to solve a flat spot when the car is cold, by process of elemination, I have done the following:
New blue temp sensor and tested at ECU
Checked for air leaks on the intake side
Injectors reconditioned
Mixture set at 1%
I'm now testing the AFM and a spare at 20 degrees C and have got the following results:
AFM 1: CAR
ohm range 2980 to 4040, IAT 3350
9V battery 0.46 to 8.61
AFM 2: SPARE
ohm range 2880 to 4600, IAT 3190
9v battery 0.45 to 8.49
They are similar results, I just wanted peoples views as to whether these reading are what should be expected from a correctly working AFM.
I'd be interested to know other peoples result when tested at approx 20 degrees.
PG.
325i AFM Testing
e301988325i
It's good to see someone being proactive and taking sensible steps to cure their issues!
Mixture set at 1%
Assuming you've completed these steps in order? I would ask where your flat spot is, and secondly to describe the issue. If just off idle then it suggests the tps is not set/functioning as expected. Is your cold idle higher than when up to temp?
Mixture set at 1%
I said:
e30topless said:
lock the wife in there
PG325
The rpm is higher when cold, it's literally as you blip the throttle from idle, I did a couple of videos in August 2010!!!, it's been that long living with it, to be honest by time I get it out the garage and drive a few hundred meters it usually sorts itself. There is a whine or whistle that you can also hear on the video.e301988325i wrote:It's good to see someone being proactive and taking sensible steps to cure their issues!
Mixture set at 1%
I am leaning towards the TPS not being set correctly and this is a part I did swap, if the AFM figs look OK I might check the TPS next.
e301988325i
two possibles:
1) TPS not registering idle - in which case when you resolve the issue the Co will need setting to 1%.
2) The TPS has been set so that the idle switch does not disengage quickly enough, in which case this will be a very simple fix.
I strongly suggest beofre you move anything you use a multimeter to determine which issue you have.
The TPS's tend to fill with oil dripping down the TB shaft from the crankcase breather. Drill a 2mm hole in the lowest part of the TPS to drain this
I said:
PG325
The TPS does click as soon as the throttle moves, I will however check the readings, also make sure the butterfly is correctly positioned with the TPS then reset if necessary.e301988325i wrote:two possibles:
