engine flush
jimbob29
Post Fri Jan 27, 2012 12:07 pm
is it recommended to do an engine flush prior to an oil change'or will flush unwanted crap back in to engine?
Post Fri Jan 27, 2012 3:11 pm
You'll never get a straight answer to this.
Some people will tell you that engine flushes just dont work.
Some will tell you that they dislodge all the crap out of your engine which subsequently makes the oil pump shat itself.
Personally I've used engine flushes on almost all my cars since my first one in 1993 and never had a problem with them. As long as you follow the instructions, get the oil bastid hot and drain it straight out you should be fine.
