318is starting problem.
dave_noble
Hi i've recently got a 318is. When i try to start it from cold it doesnt like it the first time, leave it a couple of seconds and she fires up and runs fine. Anyone have an idea what this could be?
jon-m42
blue temp sensor possibly....its placed under the inlet manifold however i could be wrong so do await for confirmation from one of the gurus on here they are a great help
jon m42
jon m42
Grrrmachine
- E30 Zone Wiki / Team Member
The fuel system should be pressurised. If you've got a small leak (such as perished hoses or dribbly injectors) then it'll take some cranking to get the system back up to pressure.
Test the blue temp sensor via the method here:
http://www.e30zone.net/e30zonewiki/index.php/Blue_Plug
if it checks out ok, check your fuel system for leaks:
http://www.e30zone.net/e30zonewiki/inde ... Components
and if you can't see anything obvious, send your injectors off to injectortune for a rebuild. In fact, send them anyway
