First point of call to stiffen ride quality of a cabriolet
jamespb
Post Mon Jan 23, 2012 11:40 pm
Looking for some advice please,
Just starting to plan some work on my '88 cabriolet for the summer and looking for some pointers, the main thing I want to work on is the ride quality.
I know it is an inevitable problem with convertibles in general but mine seems to roll and tip around corners like its sitting on a water bed.
I am not looking to turn it into track-day suspension - just make the steering a bit more responsive and keep it a little more level when cornering.
So... any advice on what the most effective changes are? What gives the most improvement versus £££ spent.
I have been advised by a friend who had an old Saab aero convertible that he got a massive improvement by adding a front strut brace? I found a couple on ebay ranging from £20 to £150, does the quality/price of these parts make any difference? Anybody out there fitted a budget or expensive one?
Also, found this pretty impressive video of what Bose can do with a suspension system (that IS Bose the audio/speaker company) the video is pretty ridiculous.
[youtube][/youtube]
**BANNED**
Post Tue Jan 24, 2012 11:06 am
New set of dampers all round.I fitted Borge gas filled one's to M-tec spec bought from GSF.
Youth is wasted on the young.
Rtaylor2208
Post Tue Jan 24, 2012 11:30 am
New Springs and dampers as you'll probably find the originals are still fitted. Most recommend eibach pro springs and blisten dampers (B4, B6, B8) the higher the number the stiffer they are. Budget £350 to £400 plus fitting.
On top of that
Eccentric M3 bushes for the front lolipops about £40 for the pair from BMW, again plus fitting.
Rear trailing arm bushes, front ARB bushes, Rear ARB bushes, subframe bushes and diff bush.
The bushes are not hugely expensive from GSF \ ECP but labour will cost you for fitting if you dont have either the skills, tools or time to do it.
Morat
Post Tue Jan 24, 2012 4:10 pm
B6 and B8 are similar "stiffness" just different lengths to accommodate standard/lowered springs.
But B4 are standardish and B6/8 are stiffer.
