Single mass flywheel?
phi1
Post Thu Jan 19, 2012 9:45 pm
Hi there,
Was wondering what people were using for flywheels with the 6 speed box? also what clutch? I want to use a single mass one. (solid)
I don't mind ordering from the states just wondered what people are using.
Cheers Phil
yamoda
Post Thu Jan 19, 2012 11:02 pm
phi1
Post Fri Jan 20, 2012 12:20 am
yamoda wrote:Here you go...
http://www.ttvracing.com/
Sent them a mail, any idea how much they are? also any other ideas? can you use any from another bmw?
yamoda
Post Fri Jan 20, 2012 7:55 am
I got a flywheel for a M62B46 from them and it was around the £300 mark. I'll be using the same box as you and the flywheel is machined to use a clutch from an Evo M3 which, I think, is similar to the E39 M5 clutch.
Driftben
Post Tue Jan 24, 2012 8:22 am
i got a lightened flywheel made to use a M5 clutch from http://www.Bigbavarianbeauties.com
hes a nice fella so drop him a line, he knows his stuff.
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
FormerMember
Post Tue Jan 24, 2012 5:46 pm
That looks like very heavy piece of flywheel. Sure it's easier regarding clutch (original bolts on / dimensions "right" without modifications) but bringing the "clutch face" so much aftward increases weight and costs (you'll need quite a chunk of metal to make that from)..
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
e21Jason
Post Tue Jan 24, 2012 8:28 pm
The BBB looks identical to the TTV one and the TTV one is lighter than an stock m62 one (had both in my hand) they use an m5 e34 clutch (I think) which has a sprung hub.
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
phi1
Post Fri Jan 27, 2012 10:34 pm
Well I was going to order a TTV one but they have a 3-6 week lead time. Any other suggestions?
