Flickering temperature gauge
randomspeedfreak
Post Thu Jan 19, 2012 2:03 pm
ive got a problem with my temperature gauge. sometimes, usually when the car is hot the gauge either creeps up and then bounces around. or bounces up and then back down again
the temperature sensor is brand new and the engine is a m52 converted from a m40. the gauge did this before when i had the m40 in, ive just forgotten about it until now!
obviously its a bit of a big deal, as the m52 is ally block so if it overheats its tears o'clock!
im assuming this is probably an earth, so where is are the earths for the gauges? if it isnt could it possibly be the gauge itself?
Cheers,
Matt
MrBenn
Post Thu Jan 19, 2012 2:22 pm
I think this is caused by the brass nut on the back of the instrument cluster being loose.
Rtaylor2208
Post Thu Jan 19, 2012 2:44 pm
Most likely the brass nut on the back of the temp guage, not too difficult to remove the cluster. There is a remoing the dashboard guide in the tech help section which covers it in detail.
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Jan 19, 2012 2:49 pm
randomspeedfreak
Post Thu Jan 19, 2012 2:53 pm
thankyou boys perfect answers as usual!
lucky for me the car is a state at the moment and the dash is half apart anyway!
quick fix for this weekend i think
grrrmachine sorry i should have checked the wiki - i usually do and appreciate all your efforts compiling it!
