Hi fellas,
I seem to be having a idle problem on cold start ups, it never used to be a problem but recently I'm having to keep my foot on the gas for a good few minutes until the engine warms up...
When this happens on a first start, i tend to pop the bonet and lightly tap the idle valve with a spanner. After which, when i go to start the engine i no longer need to keep my foot on the gas..
Do you think i need to replace my idel valve with a new one??
idle problems.. 325i
Rtaylor2208
Probably wont need replaced but cleaned out. Remove the ICV by disconnecting the pipes between the Airbox and throttle body, remote the wiring connector. Clean through with carb cleaner and put it all back together.
This is not the only cause of a poor idle but will get you started.
After this you are looking at:
1. Testing the blue temp sensor
2. Testing the ICV
3. Testing the AFM (You really need a gas analyser for this one, so down to the friendly MOT man)
4. Check all hoses for air leaks, i.e. loose fittings, cracked hoses etc.
Probably more that I cant think of but someone else can point out anything I have missed.
P.S. The wik is your friend for all of the above.
2. Testing the ICV
Tripper
Brilliant! Thanks Rtaylor for pointing me in the right direction..
I'll try this over the weekend
