Gearbox and Diff oil?
320Touring
Post Thu Nov 03, 2005 12:21 pm
Hi guy's
sitting bored in work trying to compile a list of " things to do" to my touring :D
getting a bit costly :eek:
however, i've decided that i really should do the diff and gearbox oil as its probably overdue!
What i'd like to know is what oils do you recommend?
box is standard 320i box and diff is 4.10/4.27 small case
thanks
JOSEMI
Post Thu Nov 03, 2005 12:37 pm
the parameters for the gear oil are 90/API GL4 (1.15L), although all of this is explained in the E30 car book, including the diff oil and the engine oil.
Jose
astondg
Post Thu Nov 03, 2005 11:27 pm
Well I probably wouldn't recommend anyone else do this just incase and you might think I am stupid but I am using automatic transmission fluid in my 323i's manual gearbox. Because of the age of the gearbox and it being very worn ATF has been recommended to me by a few people, including a mechanic, to help make the gearchanges smoother and easier. It seems to be fine so far (I have been using it for the last 10,000 to 15,000km).
Aston
BMW E30 323i with some stuff
1:21.67 @ Morgan Park Raceway
JOSEMI
Post Thu Nov 03, 2005 11:33 pm
that's not being stupid mate, if it works then that's a step in the right direction !
good for you !
Jose
kenwoir
Post Fri Nov 04, 2005 7:42 am
I have MTF which Honda use in their type R cars and also Land Rover in their 4x4's. A mate used it in his CRX and said the difference was superb, i was thinking of using it in my 325i sport. Anyone think this is a bad idea?
JazzMan
Post Fri Nov 04, 2005 10:07 am
I've just put Silkoline Syn 5 in both my diff and gearbox. Feels very smooth compared to before moving them by hand. Not had either running yet though! It was the Oilmans recommendation.
