320I BAUR TC '88 - ELECTRICAL PROBLEMS
paulwwww
Post Fri Jan 13, 2012 6:24 pm
I've got a 320i that's been off the road for some time. I finally decided to sort out the issues and get it on the road. When i took it for MOT the only gauge working was the speedo so I assumed duff batteries in the instrument binnacle. Garage rang to say alarm was playing up so I arranged for someone to disconnect it as it was old. When I went to collect the car heater fan doesn't work any more nor do warning lights for anything except alternator and battery u/s. I think that he's disconnected something that he shouldn't have.
Any thoughts anyone?
I can't find power to the heater switches and the fuses all seem to be ok. There's just under 0.2 amp current drain with ignition off completely - is this about right?
Post Fri Jan 13, 2012 9:17 pm
Last things first: 0.2A drain is extremely high - 0.03A is typical, with an absolute max. of 0.09A, and I wouldn't be happy with anything like that until I'd identified where it was going.
Most of this could be the alarm, depending on how they 'disconnected' it.
Heater fan: Do the door mirrors work?
Are you saying ALL the warning lights (main beam, indicators, etc. etc.) except the battery one don't work? Information you give has to be accurate, if you want useful replies.
Welcome to the zone on behalf of the management, BTW!
paulwwww
Post Sun Jan 15, 2012 9:49 pm
Thanks for that Brian. The inoperative warning lights I was referring to are those that come on with the ignition, prior to starting the engine ie oil, charging etc. Also as soon as the battery was connected the yellow and red service indicator lights would glow really brightly. Having read the wiring diagrams agin I checked fuse 10 and found that it was blown. A new fuse restored those warning lights and heater fan and the current with everything off is now 0.07A.
The thing is that as soon as I selected reverse (it's automatic) the fuse blew again so I think that the fault lies either in the reversing lights or their switch. Selecting forward gear positions doesn't blow it, only reverse. So next weekend I'll check out this circuit and then move on to the next issue - getting the instruments to work!
Thanks again.
Paul
