As above will a red label 318i m40 ecu start a car thats cat eqipped
all i need to know is will it start and move the car
if it rus lumpy i dont care
Will red label ecu work in green label ecu car
Will a normal 318i ECU Start a 318i with Cat car?
AFAIK all M40B18 ECUs are interchangeable. On some models a wire under the bulkhead wiring cover needs unplugging if the ECU is run with a lambda sensor, and the very latest AFMs can't be used without a lambda sensor.
Yep they are just drove 45 mins to magpies house to get one
