Rear knocking noise, top mounts ?
bmw9818
Post Wed Jan 11, 2012 3:10 pm
Been hearing a rear end knocking noise over last few weeks, I replaced the rear mounts with apparently heavy duty mounts from eBay....
The car was tight when I first drove it after i lowered it around march last year, but it's now really soggy! When I have about 3 ppl in the back the car makes a really disturbing thump, the wheels arnt hitting or touching, but the people in the rear can feel the bump quite badly,
I bought the shocks and sprigs off the zone, apparently fronts are eibach, but no logo, rears are ta technix, it's only a 40mm drop but car looks too low,?
Any ideas
mrLEE30
Post Wed Jan 11, 2012 3:14 pm
three in the back woudl mean the thing is so low and the exhaust will be close to the trailing arms, my money is on this hitting. does it thump when no one in the back?
cheap springs can sag after use, or worse they can snap. yours could have done either.
soggy handling is more likey due to bushes
bmw9818
Post Wed Jan 11, 2012 3:21 pm
its not as loud when no ones in the back, but can still hear it, when going over a bump, not sure how long the guy had the springs before he flogged them onto me, but for a 40mm drop it looks pretty low! think i might invest in some eibachs, or any other reccomendations?
eibach springs and shocks? polybush the rear end and e46 cab top mounts, + a rear arb
kam-325i
Post Wed Jan 11, 2012 8:35 pm
check the rear beam bush's. When these fail, they can lower the back end by around 10mm
Post Wed Jan 11, 2012 11:23 pm
Have you fitted the load spreading washer on the rod of the rear dampers, under the top mounts. They last about a fortnight if these washers aren't fitted.
bmw9818
Post Thu Jan 12, 2012 12:03 am
http://www.visionracingdevelopments.co. ... lted_l.jpg
This big washer resting on the mount? I copied the original setup, from the shocks i removed however after my dad came home there was a bit of uncertainty when he checked it....
I'm not 100% if I've done it like in the pic, I need to check tomorrow, I think I've got it the right sequence but it may be upside down, face down on the mount not curved up.....
Post Thu Jan 12, 2012 12:05 am
That's the washer ABOVE the mount. I'm talking about the one that should be UNDER it.
bmw9818
Post Thu Jan 12, 2012 9:20 am
Oh right, nah I don't think I did put one under there, the mounts just resting on top of the shock and I just tightened it on
Jos
Post Thu Jan 12, 2012 9:52 am
You'll be needing a new set of top mounts then :) Is the damper is poking up through the mount?
'94 e36 tree climber
Post Thu Jan 12, 2012 9:58 am
Jos wrote:You'll be needing a new set of top mounts then :) Is the damper is poking up through the mount?
That explains the knocking noise then!
How on earth do you think that little bush can take all the damping loads???
bmw9818
Post Thu Jan 12, 2012 10:02 am
Yeah I done it in the same way as in the pic in link above, it's an encased shock so yeah I just dropped the mount on and bolted down
loogie
Post Thu Jun 07, 2012 3:24 pm
This explians why my top mounts have recently failed there is no bottom washer fitted! Is it the same shape and size as the top washer?
bmw9818
Post Thu Jun 07, 2012 4:33 pm
its a bit rounded like a dish, there available from bmw for a few quid,
loogie
Post Thu Jun 07, 2012 4:55 pm
Thank you will see if GSF sell them.
