Hi guys,
Got home last night and noticed that my battery light stays on with the ignition off. Did a bit of Googling and got the impression that my alternator may be kaput.
This morning, no surprises, the battery is flat and the car won't turn over.
Any ideas? I'm very much a newbie when it comes to mechanics, but I don't want to get it towed to a garage and get ripped off, can't afford pricey repairs, being a student and all!
Battery light stays on! Alternator?
Grrrmachine
- E30 Zone Wiki / Team Member
Alternator's definitely not charging, but you need to ask why.
The alternator works just like the dynamo on a bike (sort of), and it has two thick cables coming from it. One goes to earth (the car body), the other goes to the starter motor and then to the battery. If any of the wires comes loose,
The alternator is driven by a basic rubber belt from the front of the engine. If that belt comes loose or breaks completely, the alternator won't be charging the system.
Basically, open your bonnet and check those wires and the belt before you go spending money on a new alternator.
bmw9818
if all of that is okay check the voltage pack, two screws pull it out and check condition,
If the battery light was on with the ignition off, there must have been 12 volts + from the battery appearing at the small terminal on the alternator. The battery + is connected directly to the large alternator terminal, so somehow voltage is flowing from one to the other.
This flow is normally prevented by the diodes in the diode pack, so one or more of these may have failed, but it's conceivable that duff earthing of the alternator frame could also cause the light to stay on.
