Hi there, I am currently in progress off building a v8 e30, what brake servo am i required to fit where the battery used to be? I am going to be modifiying the push rods also, I already have taken the old one out and welded a plate over the whole. I am 90% sure I need a clio servo? Or can I use the one from my e34 540? also is there anything else I need for the brakes? What master cylinder should I use?
Cheers Phil
brake servo question
phi1
Hi willnz I have had a look at your build what servo did you end up using? Also did pivot point on the pedal to push the rod? And did you require a booster?willnz wrote:One option is the way I did it, see here.. http://www.e30zone.net/modules.php?name ... &start=250
Glenn is also doing something similar but not too sure what his lever system looks like. See here.. http://www.e30zone.net/modules.php?name ... &start=200
Another Idea i had was installing a new pedalbox with the servo etc allready attached.
