5 lug conversion, i cant find any info here
breakermart
can anyone help as to where on here i can find detailed information on this site to swap my e30 hubs for e36 5 stud hubs. thankyou
Tay
i think you'll find that you need e36 compact ti rear hubs that will fit straight onto your existing axle unless you replace the whole beam, as for the fronts you will need e36 hubs and shocks with e30 top mounts and you'll also need e36 lower arms but i can't remember if you have to change the track rod ends so they don't touch the hub on lock????
e21Jason
did you even try looking been covered loads of times and is even in the wiki
http://www.e30zone.net/e30zonewiki/inde ... Conversion
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
You need E36 M3 EVO front bits otherwise your geometry will be pants
The only way to do the job properly is to use E30 M3 gear, but you're into £1k for the bits second hand
breakermart
thankyou both for this, i am relativly new on here and when i looked in the forum all i was seeing was parts for sale/wanted or just technical info on engine swaps. im sure if i spend more time searching then i would eventualy stuble on it but asking this way was so much easyer and quicker with your help so thanks again. lole21Jason wrote:did you even try looking been covered loads of times and is even in the wiki
