LHD US SPEC DOOR LOCK.
gooner1
Out humping Reindeer
Post Fri Jan 06, 2012 6:02 am
Would the passenger side door lock from the above, work
as a drivers side lock in a RHD UK spec car, or failing that
could I use the part with the roller bearing from either side, to make my current drivers side door lock workable :?:
Ta all.
Post Fri Jan 06, 2012 9:13 am
For LHD the whole locking system, including the wiring loom and the position of the ECU is reversed. Driver's door needs driver's door lock barrel assembly and lock motor, etc., whether LH drive or RH drive.
Having said that, there's no reason why an E30 wouldn't work with two passenger door locks, other than the loss of the dead lock facility.
gooner1
Post Fri Jan 06, 2012 10:04 am
Thanks Brian, maybe worth a try removing the barrel type ball bearing, which I mislaid while
renovating my lock, and putting it into my assembly.
Would prefer to keep the dead lock facility.
