325 radiator
johnt0709
Post Thu Jan 05, 2012 6:26 pm
How many different types of radiator can you get for the above - heard people mentioning tropical? Need a radiator for 2.5 but not sure what one has previously been in the car :?
Phase I - Bodywork Complete
http://www.e30zone.net/modules.php?name ... by+restore
Phase II - 2.8 stroker- Complete
Project II - 325 Motorsport Cabriolet Restoration.
kam-325i
Post Thu Jan 05, 2012 7:16 pm
Is your car an import or a UK Spec car ?
johnt0709
Post Thu Jan 05, 2012 8:04 pm
UK spec - Motorsport convertible.
sweep
Post Thu Jan 05, 2012 8:08 pm
johnt0709
Post Thu Jan 05, 2012 8:39 pm
Is that the correct radiator? I need a tropical.
sweep
Post Thu Jan 05, 2012 8:41 pm
That is from a 325i south african spec car with air con
cecotto479
Caution Unreliable Seller
Post Thu Jan 05, 2012 8:58 pm
Your car should have/did have a standard facelift M20 auto radiator, John.
1981 E23 735i
johnt0709
Post Thu Jan 05, 2012 9:12 pm
Will it fit - what's the correct radiator? Or should it have a normal 325 radiator? :o:
cecotto479
Post Thu Jan 05, 2012 9:29 pm
Standard radiator was fitted from the factory. Tropical rad will fit. It's just a bit longer.
1981 E23 735i
johnt0709
Post Thu Jan 05, 2012 10:08 pm
Cheers Boyd - ill get in touch next week - thought you had taken a scunner to the zone.
e301988325i
Post Sat Jan 07, 2012 12:21 pm
johnt0709 wrote:How many different types of radiator can you get for the above - heard people mentioning tropical? Need a radiator for 2.5 but not sure what one has previously been in the car :?
Off the top of my head:
manual,
auto,
manual with air con,
auto with air con,
tropical,
Basically a manual car can have any fitted, an auto needs an auto radiator. Manual with air con, and tropical rads are larger than the plain standard radiator.
I said:
e30topless said:
lock the wife in there
