Evening all,
Going through some old notes and had a breif research into cold air intakes, a few questions...
I seem to recall cone air filters are a no no on an e30, correct?
Will isolating the air box area and moving the filter closer to the grill, or even chanelling it make any differance?
I just seen some kits with 'heat sheilds' but they're awfully expensive for something I can make.
Is it worth the time?
cold air intake & K&N's
svenga
An E30 comes from the factory with a cold air intake, and an air filter system that is more than adequate for the air flow requirements of any standard or near standard E30 engine.
BMW probably spent a few million Deutschmarks developing the E30 intake, so what makes you think any fit all aftermarket tat will be an improvement?
svenga
True, however the volume of cold air per square inch for example is far higher than that of warm air, making a greater intake burning more efficient, and with a larger intake area (ie rather than the 4'' or diam of the 3 series box) will create a greater flow, although the standard box is close to the front and points away from the engine warm air is still drawn in, where as if it was completely isolated away from the heat only the cooler air could enter. Another theory (I've seen it done on a golf fitted with an audi turbo engine, well known in the vw world) an actual air cooling radiater using water vapour to cool the air flowing through (one example discharged water vapour onto a series of plates, which when the air passed through almost cooled the air to freezing temprature if rigged correctly).
I have brought this conversation up various places elsewhere along with a tuning company, who seem to agree although only a small increase in fuel saving and boost, on a standard engine, it is worth doing for the material costs.
kam-325i
1 cubic litre of cold air is the same volume as 1 cubic litre of warm air.
The difference is in the density of the air, not volume.
