X-pipe +/- & position
steve_k
Post Sun Jan 01, 2012 9:48 pm
Right then in the next few week's i'll (hopefully) be looking at getting an X-pipe for my M20B25 (mildly reworked) & i've been looking at the one's from jetex in stainless steel.
& i was wondering what the pro's & con's of fitting one are & where the best position for it would be?
I was thinking of putting it just on the end of the down pipe's or would it be better off closer to the middle box?
any thought's good or bad are welcome.
disscuss.
steve_k
Post Mon Jan 02, 2012 2:49 pm
BTTT
come on folk's surely someone on here must have an opinion on X-pipes or experience with them??
Post Mon Jan 02, 2012 3:23 pm
from what I have seen of x pipes on 6 pot donks, they tend to go after the downpipes and before the first silencer, whether there will be any difference in performance remains to be seen.
steve_k
Post Mon Jan 02, 2012 3:25 pm
cheer's for that lee :D
thats the position i thought it would be best to go for.
Post Mon Jan 02, 2012 5:27 pm
Usually they are positioned midway between the manifolds and middlebox
(pilfered pic)
Post Mon Jan 02, 2012 6:04 pm
Been on the hot tuning website Dan? :)
Post Mon Jan 02, 2012 6:09 pm
the general rule is they are placed at the hottest point from the collectors. The hotter the gasses the faster they travel and X pipe is there to "scavenge" i can't explain it very well but basically its where one side of the exhaust is pulling the gasses out from the other side.
Your camshaft choice will also effect where this hot point will be. X pipes low you a touch of low end grunt too, but for more up top
steve_k
Post Mon Jan 02, 2012 7:15 pm
Thanks for the reply's guy's :D
Simon13 wrote:the general rule is they are placed at the hottest point from the collectors. The hotter the gasses the faster they travel and X pipe is there to "scavenge" i can't explain it very well but basically its where one side of the exhaust is pulling the gasses out from the other side.
that's what i'd seen on a few websites that where selling them (in the USA :cry: ) but i thought i'd ask on here as i knew a few folk would be able to help winkeye
Nearly forgot to add the cam i'm using is a cat cams 274dg (ish).
reggid
Post Tue Jan 03, 2012 8:14 am
i just bought a BTB3 set and will be modifying the X-pipe position to see if it does what i think it will.
E30 325is with M20B31
steve_k
Post Tue Jan 03, 2012 9:10 am
reggid wrote:i just bought a BTB3 set and will be modifying the X-pipe position to see if it does what i think it will.
let me know how you get on please dude winkeye
gooner1
Out humping Reindeer
Post Tue Jan 03, 2012 10:53 am
What do you think it will do?
Eddie25
Post Tue Jan 03, 2012 11:32 am
+1 i'm sure i've heard a trick the V8 boys use in the states where they apply paint to the exhaust without any x pipe and run it. Where the paint is most burnt aka the hottest point is where they install the X pipe or often H pipe in that case.
Rust is lighter than carbon fibre.
reggid
Post Wed Jan 04, 2012 1:32 am
closer to the engine the more lowend and topend, the further away the more midrange.
steve_k
Post Wed Jan 04, 2012 11:35 am
well reggid you've just answered my main question with that one statement :cool: :D
reggid
Post Wed Jan 04, 2012 8:09 pm
steve_k wrote:
reggid wrote:
gooner1 wrote: What do you think it will do?
but what it actually does may be completetly different :)
steve_k
Post Wed Jan 04, 2012 8:23 pm
reggid wrote:
steve_k wrote:
reggid wrote: closer to the engine the more lowend and topend, the further away the more midrange.
very true indeed but we'll just have to wait & see winkeye
steve_k
Post Tue Jan 24, 2012 9:24 pm
Well fingers crossed I'll be ordering a X-pipe next Friday & trying it in a few positions between the down pipes & the middle box (got a few meters of T304 grade stainless steel pipe to make up the pipes to link it all up). Just wonder if the arse dyno will notice any difference/improvments after it's been fitted.
steve_k
Post Tue Jan 24, 2012 9:35 pm
shaun_89
Post Tue Jan 24, 2012 9:56 pm
The x-pipe shape, taper angle and length all determine how it affects the engine too!
steve_k
Post Wed Jan 25, 2012 5:36 pm
shaun_89 wrote:The x-pipe shape, taper angle and length all determine how it affects the engine too!
could you explain in a bit more detail??
steve_k
Post Wed Jan 25, 2012 5:49 pm
shaun_89
Post Wed Jan 25, 2012 6:46 pm
I cant find any good pictures of what i mean online so ill do my best to explain.
The x pipe works in conjunction with header length and collector design to take advantage of exhaust pressure waves to 'pull' exhaust gas out of the cylinder. The combined effect also sucks in intake charge mixture during the valve overlap period.
Obviously this needs alot of dyno time to correctly determine the best dimensions for what your engine needs.
When you bring the two pipes together you need to make every effort to keep the connection as free flowing as possible. If you can imagine two rivers flowing into each other in the shape of an x-pipe, there is going to be turbulance.
Its better to join to two together side by side in a 'Y' formation.
Most straight 6's show a good power increase when the two pipes are joined together over a length of 10-12 inches beside the gearbox.
The angle of the 'Y' pipe affects flow turblence too. A good starting point is around 7-10 degrees into one, so 14-20 included angle.
I could obviously explain this easier with pictures but i hope you know what i mean.
reggid
Post Fri Feb 03, 2012 1:40 am
steve_k wrote:Well fingers crossed I'll be ordering a X-pipe next Friday & trying it in a few positions between the down pipes & the middle box (got a few meters of T304 grade stainless steel pipe to make up the pipes to link it all up). Just wonder if the arse dyno will notice any difference/improvments after it's been fitted.
here is a hint, try putting it about 15" from the end of the primary tubes.........
steve_k
Post Fri Feb 03, 2012 12:25 pm
Hmm sounds interesting, do tell winkeye
reggid
Post Mon Feb 06, 2012 1:30 am
actually i will tell you what it should be for a more stockish engine, that is for a big hp screamer so ignore that for now.
I am using "pipemax" software which will tell the length and size of pipe for exhaust and inlet, required head flows etc, port and runner CSA depending on your targets.
steve_k
Post Mon Feb 06, 2012 12:32 pm
reggid
Post Tue Feb 07, 2012 1:39 am
reggid
Post Mon Feb 13, 2012 1:37 am
about 420-450mm is closer for a milder M20.
steve_k
Post Mon Feb 13, 2012 10:40 am
reggid wrote:about 420-450mm is closer for a milder M20.
Thanks for that dude :D
Just waiting for a dry day so I can get under the car to get everything measured up ready for fitting.
steve_k
Post Thu Mar 29, 2012 6:15 pm
Well it finaly looks like I'll be getting round to fitting the X-pipe (at long last) & seeing if there is any noticable difference.
forgot to add in the first post that the manifold the X-pipe is being fitted to is a magnex 6 branch (genuine not a copy) if that makes any difference??
fingers crossed I can do it without any faffing about lol.
e301988325i
Post Thu Mar 29, 2012 10:27 pm
dyno before and after is the only way to prove it!
I said:
e30topless said:
lock the wife in there
steve_k
Post Thu Mar 29, 2012 10:43 pm
e301988325i wrote:dyno before and after is the only way to prove it!
well there is one down the road in clowne so I might pop in before I do anything & see what happens then again after I've fitted it.
e301988325i
Post Fri Mar 30, 2012 6:58 am
You've got to, I know it's an extra £50+ for two runs but a subjective, 'it feels faster' just doesn't mean anything unless you can quantify it, timed runs also count but it's very hard to get similar weather conditions whereas a dyno is compensated.
I said:
steve_k
Post Fri Mar 30, 2012 9:40 am
e301988325i wrote:You've got to, I know it's an extra £50+ for two runs but a subjective, 'it feels faster' just doesn't mean anything unless you can quantify it, timed runs also count but it's very hard to get similar weather conditions whereas a dyno is compensated.
I know what you mean.
I forgot to add that I'm making sure I can change the position of the X-pipe to see what different results I get I;E first run with out it, second run with it fitted at the end of the down pipes, third run with it fitted closer to the middle box & take it from there.
mpereznoble
Post Sun Apr 01, 2012 4:42 pm
Does the sound change?
