The Touring will change gear at 4800rpm if your flooring it in D, if you use 1-2-3 it will go all the way to red line. It also wont kick down when you plant throttle at 55-60mph
Anyone and ideas
Does it need a new kickdown cable ?
Oil is bright red and not black/brown and smelly.
m40 318i Auto Early upshift crap kickdown
First question has to be: is it an electronic auto or the old type non electric? (Does it have a rotary knob on the rear console?)
No rotary Knob
I thought only the 6 pots had switchable option
You didn't say what car, and I learn't a long time ago not to make assumptions on here based on members' sigs.
Don't know a great deal about autos, but I'd say checking the adjustment of the kickdown cable is probably the first, and possibly the only, thing to check.
Its in the title
Do you know how i would go about adjusting it, i did a search earlier and i read a few memeber who adjusted them and ended up with the cars not going out of first gear
to be honest the plastic bit on the throttle body that holds the cable has snapped and its come away from the clip, Not sure how to describe it prehaps a picture may be better. like 50% of most e30 throttle cables
Anyway would that cause any issues?
mark up the cable so you can reverse what you have done if needs be alex, then try it one way or the other, because it's not changing down i suspect it's loose,
IIRC it's called a bowden cable
ive updated the above post, would that cause a problem ?
£50 for A New kickdown cable
are they as hard to fit as people say ?
