hi i have bmw e30 convertible
i bought some alloys 16x8j et 25 on frt and 16x9j et 35 rears what tyres size would you recommend that will be perfect for chucking the car around and also that looks good with out scrubbing the arch and popping off i will be putting coilovers on aswell i wouldnt mind having slightly stretched tyres
16 inch / 8j front 9j rears what tyre size will be perfect
billypakiboy
What sort of drop are you running Billy?
billypakiboy
its on orignal suspension at the moment buddy but will be putting coil-overs soon as well
if there's some ghetto lows on the way then you'll end up needing some arch rolling and to run some stretch tyre shizzle.
I don't know the specs for this, so I'd wait for a brother to come along who may know more
Shazam
Shazam
With the ET being quite high on the wheels, I reckon you'd be ok with a 225 tyre on the rear without any rubbing on the arches.
Or go with a 215 or 205 40 tyre for some stretchness, shouldn't rub then.
I was running 9x16 et15 on a 40mm drop with 205/40 tyres with no problems.
