Tec2 apron panel fitment
Jozi
Post Mon Dec 26, 2011 2:27 pm
I'm looking for some comment on the tec2 panel fitment with my front panel. Does the front panel look slightly bent or is the apron a little distorted? The 2 vents on the apron don't quite line up properly with those on the front panel, I'm thinking they should?
It's a little hard to see in the pics cause of the similar colours. The apron vents seem to sit slightly lower than those of the front panel, also the apron looks to sit a little proud of the front panel. The panel is slightly bent backwards but i'm not sure if it is also bent up and causing the vents not to line up properly.
Post Mon Dec 26, 2011 7:09 pm
have you used the 5 plastic clips that attach to the steel Valance like in this pic ?
Jozi
Post Mon Dec 26, 2011 7:28 pm
Not yet, I was just pushing it on to see how it fitted, noticed the bottom was a little bent and then noticed how the grille holes lines up. It was only after I posted I had a look at the wiki and found the article on the tec2 apron.
I'll drill the holes tomorrow if I'm feeling up to it, if not than the next day and see how it lines up etc.
mrLEE30
Post Tue Dec 27, 2011 4:33 am
Looks fine to me, but the white clips are required otherwise it will sag.
Jozi
Post Tue Dec 27, 2011 2:25 pm
The centre piece of the apron looks slightly lower than the centre piece between the 2 vents on the valance. I'll get it mock fitted and see how it is.
I think I have 7 of those white clips but there's only 5 places for them on the top edge? Did I miss 2 more or buy to many clips?
mrLEE30
Post Tue Dec 27, 2011 5:29 pm
There are seven clips but two on the outer edge, they are very hard to fit and I did not see what benefit they would have versus the hassle of fitting, so I only did the five middle clips.
There are many different front valances some with none, one or two vents depending on spec AC oil cooler etc, but once fitted you will not notice if they don't quite line up.
If you are about to paint your tech 2 valance use a plasticiser otherwise it will crack the paint as it flexes, and I sprayed the bottom quarter inch and the lower edge with rubberised spray paint as it get scratched easily especially on a lowered car, now I just mask mine and reapply the rubberised paint every couple of months.
Jozi
Post Tue Dec 27, 2011 7:39 pm
Whole car will be painted next year, will make sure the painter uses a plasticiser when he does the apron.
Didn't notice the 2 outer ones until you said it. On the inside of the apron at the edges there's a tab either side over which you slide a clip with a screw on it, are these needed? I'm missing them on both sides where some careless person cracked them both of, along with one bracket on the bottom edge missing :-x
mrLEE30
Post Wed Dec 28, 2011 10:08 am
as you see from the pic above i only used 5 clips,
i also did not use the upper side clips you speak of as quite frankley i could not be bothered drilling more holes in my valance so close to the wheels (as they woudl get wet and rust!), and one of the plastic brackets (circled in green upper left)was broken on the spoiler the main ones you need are the five clips and the lower holes and bracket (also circled in green but on right lower)
In the end i just used some black silicone sealant to hold the sides in place, it needed reapplying about once a year but never gave me grief to be fair, and only popped off when i bashed into something!!
Jozi
Post Wed Dec 28, 2011 10:11 am
I might just use silicone for the ends then, seems like a much more panel friendly approach. I've one broken clip like the bottom one above, I'll make up a bracket out of steel instead.
mrLEE30
Post Wed Dec 28, 2011 10:25 am
its a bit of a bodge but better then trying to make up new brackets on the spoiler only ot have them fall off anyway. as i say in the wiki, if you have them and thay are not broken then fit, if not then glue!!
From memory there are several lower holes that are on the tech 2 lower spoiler (my srewdriver through one below)
these serve the same purpose as the bracket you mention that is broken, but if you oly have the three in the middle it may put strain on your silicone bodge and will be annoying as it falls down all the time!!
so yes make an effort to repair these.
Aslo the BMW kit used plastic expandable bolts for these lower holes, these are not worth using in my opinion, i went to a hardware shop and bought teflon/plastic M5(or M4?) x 30 nuts bolts and washers and bolted the lower part to the car, its fiddley but worth it, BMW used expandable bolts becasue they are cheap and easy to fix, but one parking crunch of the spoiler will break them...very annoying!!
