Central locking- Brianmooore
darren_mk
Post Sat Dec 24, 2011 4:27 pm
I touched on this problem a few months ago-
1989 325i Sport
Passenger door wont lock/unlock -
Brian advised to check the e/l mirrors, so to rule out the door connection. I can now advise that the drivers mirror works ok, but if i flick the toggle to the passenger side it dosent work - but the drivers mirror makes a few clicks and noises.
Does this sound like a bad earth?
Post Sat Dec 24, 2011 8:53 pm
An E30 door mirror only has one motor in it. When you power the motor, it moves the mirror from side to side.
There is a second device in the mirror that looks almost exactly like a motor, but is actually a magnetically operated clutch, which changes the motor drive from side to side to up and down, so, to move the mirror up and down, both the clutch and the motor have to be powered.
Whenever you move an E30 mirror up and down, the motor power is applied to the mirror you are moving, but the clutch power is always applied to both. This results in both mirrors making quite a loud 'click', but you normally don't notice because of the motor noise from the mirror that is moving.
Your passenger mirror is not getting its motor power, so you are easily able to hear the perfectly normal click from the driver's mirror.
Does the passenger door mirror click as well?
Each mirror has four wires - two for the drive motor and two for the clutch. For the passenger mirror, these four wires go through four pins of the passenger door plug and socket, and three of them also go through the driver's door one as well, so you can see there is plenty of opportunity for malfunction.
The most likely one to have corroded are the ones that are live all of the time the ignition is on. These are the blue/white and the black/white wires. To determine which, earth the black/white (blue right at the motor) wire, and see if the motor runs. Don't move the mirror switch while doing this!
If the motor runs, the problem is with the pins on the black/white wire, if it doesn't, the pins in the blue/white are at fault.
Occasionally, the mirror switch is the problem, so try a known good one first, if you can get your hands on one.
darren_mk
Post Wed Dec 28, 2011 4:26 pm
Thanks Brian -
I tried a known good mirror switch and then found the following:
Drivers side works fine, but passenger side only make a click on one axis of the switch, the other axis does nothing.
So i earthed out the black/white and still nothing is happening.
So i presume i have a problem with the blue/white wire as you state?
Is this all related to the central locking?,as that is my biggest concern - Everything works fine- drivers door, boot, petrol flap and the boot will also lock the car. But the passenger door does zero - I have done the red/black wire mod etc....
Post Wed Dec 28, 2011 7:08 pm
Nothing to do with the central locking.
The pins of the red/black wires in the door socket (driver's door only) are the most likely pins to corrode, since they are always live. The next most likely pins to corrode are the ones that provide 12 volts to the door mirrors, since they are live all the time the ignition is on.
The problem with the passenger central locking could be caused by corrosion spread to the relevant pins for that.
darren_mk
Post Thu Dec 29, 2011 3:48 pm
All sorted with it now. Problem was a cut in the loom - i was lucky to find it.
Can i ask what the difference is with the actuators -
I have some with a black cap on the end and one with a blue cap.
The blue one is the only one which works on the car - Its a 2 door. I am thinking the blue ones are 'master' which will send a signal to lock, and the black ones are for the rear of a 4 door?
The only other minor issue is that the passenger door wont lock the rest of the car - Could the actuator be faulty?
