1989 325i Sport -
Im building it all back up after a major stripdown by a bodyshop.
The problem is that the red led on the LIMIT button on the 13 button obc is always illuminated after the battery is connected.
It will go out if i flick the toggles on the interior lights to another position.
What could cause this strange problem - a bad earth maybe?
The door switches all work fine, the relay is working away and the windows/sunroof etc work with the doors open, just not the interior lights.
Strange electrical problem
darren_mk
Well, you've got me on this one! No ideas or suggestions whatsoever.
The OBC is all pretty much self contained with most of the functions and its power feeds coming directly from the instrument cluster. Not much scope for getting things wrong!
If you've had the interior lights disconnected, check that you've connected the red/green wire to the end of the bulb furthest from the switch. With the wires wrong, the lights will work on the switch, but not when a door is opened.
The door pin switches are two switches in one. The roof/window relay uses one switch, and the lights the other, so it's possible for one to work and not the other with a faulty pin switch.
