Gauge needles
dooce
Post Fri Dec 23, 2011 9:44 pm
My speedo and RPM gauge needles don't light up 100% like my other gauges do when I have my lights on. The tip does not light up, but the rest of the needle does. It only does it on these two needles, the rest are fine. I am not sure what gives the needles the light, but can it be replaced easily?
Post Fri Dec 23, 2011 11:37 pm
All the light for the gauges is provided by two 3W bulbs (don't fit bigger, or things will melt) and plastic light guides.
The last E30 I bought had poor light to the gauges, and that turned out to be that some muppet had painted the bulbs blue and removed the light guides!
Apart from checking that the bulbs haven't gone black with age, and that the guides haven't gone AWOL like mine, there isn't much else I can suggest.
You do know about the rotary dimmer built into the main light switch?
SGP
Post Sat Dec 24, 2011 2:06 am
careful cleaning can help some.
If it ain't broke..
Fix it till it is :)
dooce
Post Sat Dec 24, 2011 9:25 am
Thanks for both of the replys. I will pull the cluster over the weekend and see whats going on and replace the bulbs if I can find some next week.
Brianmoooore- yes I know about the dimmer. I have had this car for almost a year now but had it in storage for 4 months and just removed it and started driving it again. I don't remember noticing this before.
