What symptoms would a faulty ignition coil give.
ah
As above.
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
Anythying from no go to a load related misfire, but it's very unlikely there's anything wrong with your coil.
redcar
On mine the econometer gauge worked intermittently.
This was on a 316i m40... Changed leads and rotor arm and distributor cap and it fixed it.
Was also a very bad misfire when the car warmed up. Wouldn't start ad it would stall at low rpms
SGP
Warning, failing coil can fry the ecu. When the coil in my '89 motronic 1.1 began to fail, the car would stall at the most awkward times, cutting out and restarting mid acceleration etc. As Brian said, 'load related misfire' = a nightmare to drive - nearly caused an accident. The sad thing is that the ecu died shortly after as a direct result. It can happen. Swap a coil if you can before it's too late. Just a suggestion mind.
If it ain't broke..
Fix it till it is
Fix it till it is
