Hello
Am I right in thinking that distilled water is what you need to change your engine coolant (best practice), or will normal tap water do the job with a good coolant?
Scott
Engine Coolant Question
greg124
If you are in a hard water area (lots of dissolved minerals) its a good idea to use distilled or de-ionised water, otherwise just tap water should be fine.
I use about 1 part of antifreeze to 2 parts of water
Schadenfreude - the German's haven't got a word for that.
