Can anyone shed some light on these ?
Firstly, woke up yesterday morning to find the drivers side carpet completely soaked, and a little puddle in the rear footwell - it was raining when I drove home from work last night - is this likely to be something like a leaky door seal or should I expect the worst?
Also, the car has started stalling when I bring the clutch down, this happens once every 30-40 miles, I'd imagine its some sort of idle valve?
& when I go round roundabouts (or any sort of right-hander), the oil light comes on and I get a whirring noise and reduced power for about 10 seconds afterwards.
Any help much appreciated, ta
Problems always come in three's...
Duke137
Problem 1 - Check the elephants trunk firstly, in the engine bay on the bulkhead, it may be blocked and allowing a backlog of water in. It could be behind the drivers footwell speaker, sometime water gets in through there but more than likely it is a crusty battery tray and bulkhead or behind the pedals where that mounts to the bulkhead.
In all honesty if it is the latter you have a serious task on your hands. To fix this properly you would need to start removing a hell of a lot from the car.
I personally would advise you to remove the carpet as a bare minimum to inspect the floor pans etc and also the carpet itself will NOT dry out unless you remove it and dry it out, the sponge holds a ridiculous amount of water and all it will do if you leave it is rot the floor pan...
I would leave problem 2 and 3 until you have assessed problem 1 properly.
Good luck
Good luck
Grrrmachine
- E30 Zone Wiki / Team Member
Problem One will be the elephant's trunk drain pipe, or a rusty bulkhead. Pour water into your scuttle vents to confirm.
Problem Two we can't diagnose without knowing your car and year. But in general, air leaks in the intake system, a gunged up Throttle Position Switch or a sticking Idle Control Valve can all cause problems here.
Problem Three sounds like dangerously low oil. Have you checked the level? Maybe your oil pump is on the way out, or the pick-up tube is clogged, but either way it needs solving immediately. If it were just the light coming on then we could blame the pressure switch, but if you're seeing a drop in power then you are doing damage to your engine by running it in this condition.
More info on these issues can be found on the Zone Wiki.
sl
Cheers guys, haven't used the car today so hopefully I'll be ok. It's a 1988 320i 4dr.
Just been and checked for "problem 1" on my turd in the garage - absolutely blocked solid !
Well worth checking if you've never done it
sl
Yeah I did the same, really bunged up. Ended up snapping the trunk off trying to get it back on though!
Oil was a bit low, not on the lower marker yet though.... gonna have another look tomorrow night.
Thanks for the response guys, great stuff.
Next time, soak it in hot water first!sl wrote: Ended up snapping the trunk off trying to get it back on though!![]()
i've got a spare one knocking about I think - if you want to paypal me some beer tokens I'll get it in the post - PM Me if you want it
