Quick question,
Tried googling but didnt find much info of any use.
If I bought a set of Headlights from the US or Germany for the E30 would the beam pattern be wrong for driving on the left? Or can they just be adjusted?
James.
Headlights from Germany US etc wrong beam direction?
hammoj28
24v tech2
Cloggy Saint
Easily adjusted. There are 2 or 3 small screws on the back of the bowls, you undo them and then twist the unit and then do them back up and bish bosh, RHD headlights
hammoj28
Hehe, just what I wanted to hear. I've heard problems with other cars so thought it better to ask.
Thanks for the quick responses.
24v tech2
US spec OE head lights are sealed beam units and are not the same as european ones.
mrLEE30
As above US spec are sealed beam made by GE. And the above info on lights is only true for OE lights from Hella or Bosch. Copy lights may no adjust.
hammoj28
Ahh, ok. Good point. Thanks for the info. Think I may just have to DIY smoke mine then. Would be easier.
24v tech2
- E30 Zone Meets/Events Team
If you need the metal crosshairs for the high beams let me know.
Kedge
Smoked Hella's adjust so your safe buying them.hammoj28 wrote:Ahh, ok. Good point. Thanks for the info. Think I may just have to DIY smoke mine then. Would be easier.
