hi all,
i need to change all the bushes on my late 89 cab which started life as a 320i and have couple of questions.
1) should i use the m3 front lower wishbone bush?
2) does anyone know the standard size of the front and rear ARB bush size?
ill be changing them all to poly, can anyone recommend a place to get them from.
bushes
j2b
Got the m3 eccentric lower rear wishbone bushes on my car gives a little camber, think the cabs arb were 20mm front and 14mm rear not 100 % on this though, easy way to check is with a 20mm and 14mm open ended spanner. Powerflex online shop(link below),Ebay , rude racing ,demon tweeks etc .just have a hunt around and compare prices.
http://www.powerflexshop.com/index.php?cPath=25_85
89 more door 6 pot
rix313
The eccentric bushes change the castor angle not camber.
redcar
I thought that they change caster as well as camber.rix313 wrote:The eccentric bushes change the castor angle not camber.
j2b
+1 i forgot about the castorredcar wrote:I thought that they change caster as well as camber.
89 more door 6 pot
rix313
In theory it will effect everything but it's the castor change that is the reason for them.
aceifty
so its a yes for the M3 lower wishbone bushes
1989 cab M20B28 build
j2b
rix313 wrote:In theory it will effect everything but it's the castor change that is the reason for them.
aceifty wrote:so its a yes for the M3 lower wishbone bushes
89 more door 6 pot
balilu91
ill be changing mine next month .. and im looking at these at the moment.. they are quite cheaper than powerflex and other similar brands and they seem to be same quality..aceifty wrote: ill be changing them all to poly, can anyone recommend a place to get them from.
http://www.strongflex.vot.pl/index.php
can someone recommend these from experience?
just for your information, fitting m3 bushes will make your tyres rub slightly on wheel arch liners on full lock.
redcar
So thats what that noise was!Alex wrote:just for your information, fitting m3 bushes will make your tyres rub slightly on wheel arch liners on full lock.
