rear subframe bushing
321gazza
Need help guys, refurbing my e30 rear subframe and arms, do i need adjustable rear bushes as the car will be lowerd but not a stupid amount and also should i solid mount the subframe as i have a lsd fitted and will be fitting rpm coilovers all round and who can supply me the parts.
You dont need adjustables with only a slight drop.
"Solid mounting" the subframe is a mistake.
Is the car going to be used for road or track use ?
If its road use OEM bushes with the void fillers from DanThe
if its track then you can get away with polybushes.
321gazza
Its a road car with 300bhp so will need something that will last, not worried about road noise.
penton08
If you polybush it and fit GAZ coilovers, road noise will be the least of your worries!! Genuine rubber is fine for 300 ponies.
321gazza
So poly bushes no good for the rear then, does it make the rear more skittish then.
Ajsingh
What do the "Danthe" void fillers do? Easy to fit? As my rear beam buses are overdue replacement
E30 Crazy!
http://www.e30zone.net/modules.php?name ... c&t=208635Ajsingh wrote:What do the "Danthe" void fillers do? Easy to fit? As my rear beam buses are overdue replacement
Just picked mine up off Dan yesterday but not fitted them yet - only a 5min job per side
penton08
On the track they may well be great!! On our shity broken roads, polys and rock hard coilovers will have you skiping and bouncing around like a drift c@ck. A slightly softer rear end works well on the road imo.
And on track!penton08 wrote: A slightly softer rear end works well on the road imo.
Bush fillers will make your new bushes last 10 times longer, or take 90% of the movement out of worn bushes, perfect for winter MOT duties and they are re-useable
321gazza
fitting poly bushes to the subframe mounting points (one that go up into the sills, floorpan, one each side) do i need to replace any other parts, ie washers, spacers ect when bushes fitted.
