Quick question regarding carb cleaner
Jem
Can I do any harm to the ICV, AFM or the throttle body with Carb cleaner??
Simon
No, it's the best stuff to use for cleaning these items out, same stuff as brake cleaner.
A1BMW325iSport
not at all, its designed to clean
Jem
Thanks, my main worry was the electronics in the AFM.
Andy_magic
I have cleaned AFM's until you could eat your lunch out of them using carb cleaner with no illl effects.
Click the link below for more info.
http://www.e30zone.co.uk/modules.php?na ... ning+rough
The throttle gap should be set to .50mm though!
HTH
HTH
