Hello can i have prices for the following please
1988 M3 Evo II
31 12 9 061 222 eccentric bushes, 1 Pair please
33 33 1 126 136 M14 nut for rear bush, 2 Required
33 11 1 210 405 Rear diff gasket, 1 Required
62 16 8 355 008 Pulse/speedometer generator, 1 Required
33 11 1 206 166 (O Ring) for above, 1 Required
33 11 1 206 076 Bracket, 1 Required
62 16 1 365 817 Securing plate, 1 Required
33 13 1 208 006 Dustcover plate, 2 Required
33 41 1 124 945 Securing plate, 2 Required
31 35 1 127 202 Support shackle, 2 Required
51 71 1 884 358 Rubber cover, 1 Required
Will need other stuff but getting a bit at a time to spread cost.
Thankyou
M3 Prices please
bigbird76
Cotswoldbmw
Hi There
31 12 9 061 222 eccentric bushes, 1 Pair please £37.08 for the pair
33 33 1 126 136 M14 nut for rear bush, 2 Required £3.53 for 2
33 11 1 210 405 Rear diff gasket, 1 Required £2.27
62 16 8 355 008 Pulse/speedometer generator, 1 Required £18.16
33 11 1 206 166 (O Ring) for above, 1 Required £0.50
33 11 1 206 076 Bracket, 1 Required £3.67
62 16 1 365 817 Securing plate, 1 Required £11.08
33 13 1 208 006 Dustcover plate, 2 Required £5.29 for 2
33 41 1 124 945 Securing plate, 2 Required £0.83 for 2
31 35 1 127 202 Support shackle, 2 Required £6.77 for 2
51 71 1 884 358 Rubber cover, 1 Required £18.30
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 33090
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
bigbird76
Hi Brett can you also price these parts please
31 21 1 126 065 cup for rear of wheel bearing 2 required
51 31 1 948 155 support clip for window 3 required
51 31 8 177 850 Clamp for window 20 required
61 13 1 378 991 Relay cable bracket 1 required
16 12 1 176 297 Bracket for fuel pump 1 required
16 12 1 177 356 Bracket for fuel pump 1 required
33 55 1 129 195 Rear stabilizer bracket 2 required
51 71 1 936 929 Expanding rivet 10 required
51 11 1 908 077 Expanding Rivet 10 required
34 11 2 225 356 Protection plate left 1 required
34 11 2 225 357 Protection plate right 1 required
51 48 1 906 393 sound deadening inner top panel 1 required
34 34 1 163 565 clips for brake lines 10 required
34 32 1 154 322 Rubber grommet Dia 40mm 2 required
34 41 1 153 880 Bracket 2 required
51 71 1 933 827 cover left 1 required
51 71 1 933 828 cover right 1 required
will order all of it as soon as your done.
Leigh
Leigh
Cotswoldbmw
Hi Leigh
I understand one of my collagues has done this by email, can you please confirm that
many thanks
Brett
many thanks
Brett
Cotswold BMW Parts
01242 335365
01242 335365
bigbird76
Yes Brett but was quoted £624.42 i dont know how that is so high though i will have to ring and find out what has bumped it right up.Cotswoldbmw wrote:Hi Leigh
many thanks
Brett
Leigh
Cotswoldbmw
Hi Leigh
let me have the quote ref and i will have a look at it for you
Brett
Brett
Cotswold BMW Parts
01242 335365
01242 335365
bigbird76
Cheers Brett
I ordered the parts plus 2 new front wings. One of the parts Was £300+ so i removed that one.
Cotswoldbmw
Hi Leigh
Can you please ring Ross in our parts department on 01242 257999 he tried to call you on Friday but it looks like your phone number is wrong on our system
Brett
Brett
Cotswold BMW Parts
01242 335365
01242 335365
