1990 320i Immobiliser bypass (SORTED)
teatime39
Post Mon Dec 12, 2011 11:41 am
My Immobiliser fob is totally gone so need to bypass , i have found the control panel behind the glove box but don't know what to do next , i managed to get the car started by linking battery to coil and pins 11 to 14 to get it outside my house but what should i do to remove immobiliser safely , any help would be much appreciated
Motorhole
Post Mon Dec 12, 2011 12:55 pm
You need to determine what kind of alarm/immobiliser it is and obtain the respective wiring diagram. Compare the immobiliser wiring diagram with the car wiring diagrams and you'll find wear everything is spliced in. Remover and re-solder the connections, using shrink tube to secure and you'll be ready to go!
milescook
Post Mon Dec 12, 2011 12:56 pm
If it's like mine, http://www.e30zone.net/modules.php?name ... highlight= I just had to connect 2 green wires. There's pictures in there too.
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
teatime39
Post Mon Dec 12, 2011 1:32 pm
mine seems to be a lot more involved than yours buddy , my control box has at least 30 wires coming out of it. I've done the green wire connection and no ignition lights . it's dark now so will have a go again tomorrow
teatime39
Post Tue Dec 13, 2011 11:06 am
Sorted . Found where they butchered the black/yellow and green wires in the steering column,re-soldered them back to original ,cut the plug with the two greens soldered them together got rid of all the above wires and boxes and all is fine . thanks everyone.
Post Tue Dec 13, 2011 1:37 pm
The splices where you found them are common where the alarm/immobiliser has been fitted by the cowboys! They know that they can find the relevant wires there, and are blissfully ignorant of the connection points provided by BMW. For similar reasons, you often find the power feed to the unit taken from the back of the hazard warning switch, as there's always a permanent live there.
If there were connections to the plug with the green wires, it's possible that you have removed two alarms (not unusual at all), unless you have an OBC.
The green/purple wire that you have labelled in the pic. is the feed for either the electric windows or sunroof.
