The battery on my E30 keeps running low and then needing jump leads. I then start it every day, but if I miss a day, it's dead again.
It's about the third battery in as many years.
Today I took the old one to my garage and they tested it and found it dead. I bought a new one but before I put it in would like to know how often the car should be used to keep battery in good working order?
I drive it maybe 2 or 3 times a month and cover perhaps 30 miles if that. Could this be why the battery dies?
I thought it may have been the Clifford alarm draining it, but I didn't arm the alarm and the battery still got weak and then died. I contacted Clifford to see if my alarm had battery backup that would drain the battery, but apparently is doesn't........
If I disconnect my battery after use, will that keep my battery going for longer?
Sorry for the long-winded question. Any suggestions appreciated.
Battery probs...........
Grrrmachine
- E30 Zone Wiki / Team Member
Batteries have a shelf life of around five years, so there must be a reason you're killing them so much quicker.
You have definitely got a drain somewhere, however small; trouble is, it could be anything, and it will take patience and a multimeter to find the cause.
In the meantime, disconnecting the battery when not in use will prevent damage to it.
Does everything in the car work alright?
greentouring
Thanks, mate.
Everything works apart from the alarm doesn't sound for some reason. The key fob arms the alarm and locks it, but there is no sound. I'm sure the Clifford alarm has something to do with it. I contacted them but they are not interested.
AlpineCab
Batteries can be funny buggers. If it has been fully flat, then the battery can actually show charge reluctance i.e. it will not charge even though you are pushing current through it (lights on charger are not lit) and will show as dead.
A trickle charge for an hour may put it right, and re-alters the battery chemistry so that you can then charge as nomal. But you then you can charge to the max using the charger again or the monte-carlo method (drive fast for half an hour).
At the end of the day you just may not be using the battery enough for it be acting normal.
I have learnt all this from nearly binning a perfectly fine Bosch Silver and after having done some web R&D.
The remedy might be just to trickle charge for a good 24 hours, then discharge/charge the battery through normal use. I doubt starting the car up is enough to make up for the lost charge used in pushing the starter motor.
Sort of a jumbled reply, and maybe I've got the wong end of the stick for your issue, but this was what I found was the prob in mine. Fully trickle charging and using more often solvbed issue. Batteries need to be used to behave properly.
greentouring
Thanks, Alpine, that makes sense. I haven't installed the battery as yet and it's sitting in the boot. This is the last battery I buy for this car!
When I do I'll try to use it most days and do a few miles to keep it charged. I'll have to check the alarm out, too.
