Noisy diff after unexpected drift in the rain
tha881
Post Thu Dec 08, 2011 1:51 pm
I have a 320i with a 4.1 open diff, when i was driving home from work the other night the back end kicked out on me. The car swerved side to side a little but luckily i managed to catch it and regain grip but it was quite violent. Drove home and car seemed fine.
The next day wen backing off my drive there was a clunk from the rear as the car began to move. I was certain the drvers side rear drum had stuck and was dragging when driving. I took the cover off the drum to have a look but it all looks fine, put it back together and the brake is fine now.
However when spinning the wheel the diff is making a lot of noise and sounds quite rough. When i spin the other side it spins smoothly and doesnt make as much noise.
The handling seems to have suffered aswell and feels like the back wants to step out on me a lot more, mainly round left hand bends. Could i have damaged the diff or driveshaft? Or could it be something else? There is definitely more noise coming from the rear drivetrain? Im sure only one side has been affected and is due to weight transfer in the swerve but not sure what would cause the diff to get noisier? Any ideas ppl?
TouringTash
Post Thu Dec 08, 2011 1:59 pm
I may have a boggo 4.1 sitting in a pals garage in Bexley. FOC if you pick up, I'll send my pal a txt and get him to take a look see.
He is crap so it may take a day or two.
318i Touring
tha881
Post Thu Dec 08, 2011 2:08 pm
That would be awesome mate thankyou, im near brands hatch so bexley is just up the road
Im wondering if its something between the diff and wheel causing the rough noise though?
If i swap the diff over what other parts on the rear drivetrain woud be worth replacing?
TouringTash
Post Thu Dec 08, 2011 2:16 pm
Brands Hatch! lol I'm in NAG so if you fancy a second opinion PM me and pop over, decided to take December off so am normally found kicking back or pissing about in the garage.
If all else is good then I wouldn't bother too much as after 21 years bolts and bits tend to seize and can snap :eek:
A few diagrams here http://www.realoem.com/bmw/partgrp.do?m ... 7297&hg=33 will show whats what.
318i Touring
RichIS
Post Thu Dec 08, 2011 2:38 pm
if its only one side making the noise and ruffness could it not be a wheel bearing?
Injections nice....but I'd rather be blown ;)
TouringTash
Post Thu Dec 08, 2011 2:42 pm
Hope not as these are a pig to do.
318i Touring
tha881
Post Thu Dec 08, 2011 5:17 pm
There isnt any play in the wheel so pretty sure it isnt the wheel bearing. Been over and to see Tash and he very kindly had a look over the car, and the only part of the drivetrain of any concern is the prop donut - ive been meaning to get this done for over a year now :roll:
Might get some eibach pros in the new year too, and some sport seats..... and a slipper.....
TouringTash
Post Thu Dec 08, 2011 5:38 pm
If the worst comes to the worst and you can't get it in anywhere give me a bell and we'll sort something out as I can move mine in and out as needed as it still starts. Would be worth getting some rear exhaust hangers as these usually are rusted solid.
Anyone know if the heat shield comes out with the exhaust still in situ?
318i Touring
tha881
Post Thu Dec 08, 2011 6:32 pm
Real nice of you to offer mate :thumb:
I did message bss325i on here a while ago, he said he will quote after hes seen the car in case its a can of worms [arent they all?!!] which sounds fair enough to me, so will try and sort it with him again and let you know
Got the donut here, will get the exhaust hangers, its the ones for the back box right? Anthing else i am likely to need?
TouringTash
Post Thu Dec 08, 2011 7:17 pm
Yep rear back box ones.
Give all the bolts that hold anything onto the diff a good soak the night before and another spray before you set off to get this sorted will put you in the mechanics good books. Worth doing the exhaust as well, the heatshield bolts will have had a gentle lubrication over the years so should undo ok. Its not a shocker under there and nothing looks abused or rounded off though Barry will have a much better idea than me.
Not sure what brand this is http://www.ebay.co.uk/itm/BMW-DRIVE-SHA ... 5ae3d1ae4d
But could be worth getting. Maybe ask Barry as he'll know what to use.
318i Touring
HairyScreech
Post Thu Dec 08, 2011 8:48 pm
check the diff carefully, i cracked the spool on my 4.1 small case diff, this can result in a serious failure if left unchecked.
the result was a noisy diff and this:
tha881
Post Thu Dec 08, 2011 9:13 pm
Ta Screech, could you go into a bit more detail about what has happened there please? Looks like the big round bit is wiggling around as it turns?
TouringTash
Post Thu Dec 08, 2011 9:17 pm
I've seen girls here http://www.scarlettscabaret.com/Scarlet ... iners.html with less movement than that.
Had a good wobble underneath and the sounds and feel is from the prop. I'm waiting to hear back on an open diff to try.
318i Touring
tha881
Post Thu Dec 08, 2011 9:42 pm
Cheers Tash, pretty sure mine isnt like Screeches lol just wondered what he'd done to cause it to do that.
Theres no rush for the diff mate, will be handy to have a spare knocking about though!
TouringTash
Post Thu Dec 08, 2011 9:49 pm
With the mileage you do, 'the sooner the better' would be my mantra.
318i Touring
tha881
Post Thu Dec 08, 2011 10:03 pm
Yeah i guess so, dont like to rush anybody thats all! Be sure to give me a buzz when you find out mate
TouringTash
Post Thu Dec 08, 2011 10:31 pm
:thumb:
318i Touring
HairyScreech
Post Thu Dec 08, 2011 10:43 pm
thats in gear with the rh wheel held still and the lh rotating. (on axle stands)
the movement is a crack in the spool of the diff, which gave an odd whine above about 40.
the wiggle is due to the little gears in the diff pushing the spool apart as it turned.
only a matter of time until that let go 100% and locked solid.
TouringTash
Post Thu Dec 08, 2011 11:03 pm
tha881 wrote: The handling seems to have suffered aswell and feels like the back wants to step out on me a lot more, mainly round left hand bends.
Just re-read and this would be an dif issue? as the tyre, wheel, bearing, shafts etc, etc are all fine.
318i Touring
