Just a slightly random thought.
I live in a hard water area, would I be better topping up the coolant on the E30/other cars with water collected in the water tray of our condensing tumble dryer? I never bother buying distilled water for the job.
Cheers!
Coolant, water and Condensing Tumble dryer...
Morat
m_jermyn
demineralized water cost about 1 pound for 5 liters......
Tight northerner or what
I wouldnt use anything out of a tumble dryer, id expect it to have detergent in it at least, just boil the kettle if you dont want to buy it
- Homo Hair
Probably cost more in water and energy costs!DanThe wrote:Tight northerner or what![]()
mrLEE30
its the minerals that attack the metal that you need to remove, boiling does not remove enough to make much difference.I wouldnt use anything out of a tumble dryer, id expect it to have detergent in it at least, just boil the kettle if you dont want to buy it
In theory the water in a condensor drier is the same that has come out of your tap, so it too will have minerals in it. you could use condensate water from an air conditioner unit, but i expect you are not using your AC these days.
buy demineralised water, or just use normal water mixed with anti-freeze which has a corrociosn inhibitor in it anyway.
AlpineCab
kettle - better than tumlbe dryer - better than tap
doesn't it rain up north? theres the answer!
