Washer jets
Duke137
Post Mon Dec 05, 2011 6:41 pm
Having a few problems with my washer jet system just wondered if you guys can confirm what I think it is.
Car is 320iSE with HLWW and heated jets.
Windscreen Jets:
Basically the n/s jet works but not as good as I think it should be
The O/S Jet is crap and hardly comes out
HLWW:
I tried the intensive w/wipe, I think the motors are seized as nowt happens, even after the 4 or 5 attempts pressing the stalk in to activate it (I read you have to press it about 4 times). After I turned the engine off and had a look at the front grill the N/S HLWW Spray nozzle was dripping, this eventually emptied the washer bottle by basically syphoning itself out I guess. So is this the valve that is fooked? Also, is the nozzle requiring replacement, or would it indicate just the valve?
I am planning on stripping it all down and cleaning it out as I guess it is well and truly blocked with gunge and shyte as the car was off the road for a number of years before it was "recomissioned" in August. However, in the run up to xmas I am very busy and weekends offer precious little time and daylight to do a complete strip and overhaul of the systems, I was hoping for a quick fix now the council has introduced the gritters as basically I can't see fook all.
Is there a way to block off the HLWW completely for the time being without damaging anything which will allow me to concentrate on the windscreen wash system only without worrying about the bottle emptying itself all over the front bumper via the HLWW?
Any input would be great to save me messing about too much.
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Dec 05, 2011 6:58 pm
A lot of washer jet problems are caused by the plastic T-piece that joins them together. Replacing that would be the first port of call.
TouringTash
Post Mon Dec 05, 2011 7:23 pm
If you have a resistor give that a wiggle inside the four holes to clear the jets, though on mine they needed doing again and again so I bought new ones.
The T piece has (or did when it left the factory) a 'valve/diaphragm' to release the pressure if the jets are blocked, well thats what I think its for.
Why not unplug the power to the headlight pump to stop that, the 'plumbing' though I wouldn't have a clue and this doesn't help much http://www.realoem.com/bmw/showparts.do ... g=61&fg=45
Maybe this till you get it sorted http://www.diy.com/diy/jsp/bq/nav.jsp?a ... e=sprayers winkeye
318i Touring
Post Mon Dec 05, 2011 10:42 pm
Heated jets can be stripped right down to clean them out.
If water comes out of the small hole on the back of any of the one way valves, then they need replacing. Around £3 from BMW the last time I checked.
Duke137
Post Mon Dec 05, 2011 11:49 pm
Cheers, will try and get a better look at what is going on. I might just replace all the little valve's and T-Pieces.
Is there a recommendation for a supplier of the 'yellow' hose pipe, or is that a BMW only job
TouringTash
Post Tue Dec 06, 2011 12:08 am
If you get from a dealer make sure to say its NOT an M Tech model :wink:
You can get them at motor factors, halfords and hopefully someone will come along with a brilliant place that's cheap.
318i Touring
