M52 water in DME
fixedwheelnut
Post Sat Dec 03, 2011 8:46 pm
Weird one at work yesterday an E46 M52 engine had numerous DME faults and running problems.
Another garage had thrown Crank & Camshaft sensors at it.
I found water/antifreeze in the centre plug of the DME and corroded pins, traced this back to the 'Mapped Thermostat' leaking coolant and pumping this down the wiring loom in to the plug.
Might be worth remembering for anyone with an M52 engine conversion :)
clipper
Post Sat Dec 03, 2011 11:32 pm
8O
The symptoms you found (wet centre plug and corroded ECU pins) is exactly what happened to my E39 M54 earlier this year.... but couldn't find where the fluid had come from, eventually put it down to condensation.
What do you mean by "mapped thermostat" if I may ask and advertise my ignorance? Sounds like mine could be leaking.
fixedwheelnut
Post Sun Dec 04, 2011 12:34 am
Later engines have a 'Mapped Thermostat' it acts as a normal thermostat but is adjusted electronically to optimise the engine temperature for emmissions.
M54 engine it is in the plastic housing the top radiator hose goes to, there will be a two pin wiring plug on top if it has a mapped stat.
e301988325i
Post Sun Dec 04, 2011 4:37 pm
Just had to have my M54 electronic thermostat replaced, bloody expensive!
I said:
e30topless said:
lock the wife in there
clipper
Post Sun Dec 04, 2011 11:19 pm
Mine had been replaced not long before I got the car so I'm hoping that the ECU water damage had been done while the old one was leaking, only showing up later as the pins coroded further..... I'll be having a good look at it though :?
