Anyone know how much camber correction you can get by using camber plates (and how much +/- toe?) on the rear beam? I have them welded on as close to being centred as I could get them.
I'd like to run the touring with as little camber as is recommended.
Camber and Toe (plates)
Jozi
- Homo Hair
Depends where you have welded them..
There is decent adjustment, mine was all in spec, and it was looooooow.
Jozi
Camber plates on the inside mounts and with the plates centred over the existing hole.
What size wheel were you running? I have some fitment issues with camber dialed out
16x9 et15 225/40
16x9 et15 225/40
- Homo Hair
Checked the toe?
215 tyre 8" et20
215 tyre 8" et20
- Homo Hair
Check my sig for how far it would tuck WITHOUT any scrub!
Jozi
It started snowing in my thread
Toe seems to make little difference, I'm not sure where it should be either.
I have problems hitting that hump with the tire thats up in the arch if I dial in some camber. I also have the added problem of iX arches in which the wheels will look lost with lots of camber.
- Homo Hair
Haha. Suddenly got cold in here..
I think mine was running on the upper levels of camber obviously!
Knock the hump flat.. Be careful not to knock it into the outer skin though! Or cut it and weld a flat?
Jozi
Cutting and welding has crossed my mind! Should have done it when I fitted a new outer wheelhousing.Jhonno wrote: Knock the hump flat.. Be careful not to knock it into the outer skin though! Or cut it and weld a flat?
Seems I can flare the arches like normal and just trim away at the back of the ix arch flares
